I am experiencing issue with Telegraf SQL Server Plugin when I use a Domain level account.
Telegraf.conf SQL connection String:
[[inputs.sqlserver]]
servers = [
“Server=PMICHLAUSQL261\DEV;User id=Domain\s-dbtelegraf;Password=somepassword;app name=telegraf;log=1;”,
Error Log:
[inputs.sqlserver]: read tcp [::1]:63560->[::1]:49400: wsarecv: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:20Z D! Output [influxdb] buffer fullness: 0 / 5000 metrics.
2018-06-22T10:36:25Z D! Output [influxdb] buffer fullness: 0 / 5000 metrics.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63609->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp 10.115.17.17:63613->10.115.17.17:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp 10.115.17.17:63605->10.115.17.17:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp 10.115.17.17:63603->10.115.17.17:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63618->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp 10.115.17.17:63604->10.115.17.17:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63597->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63601->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp 10.115.17.17:63612->10.115.17.17:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63602->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:30Z D! Output [influxdb] buffer fullness: 0 / 5000 metrics.
2018-06-22T10:36:35Z D! Output [influxdb] buffer fullness: 0 / 5000 metrics.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63637->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63639->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63635->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: Login error: read tcp [::1]:63633->[::1]:49400: wsarecv: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63636->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63638->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63634->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63642->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63641->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z E! Error in plugin [inputs.sqlserver]: write tcp [::1]:63640->[::1]:49400: wsasend: An existing connection was forcibly closed by the remote host.
2018-06-22T10:36:40Z D! Output [influxdb] buffer fullness: 0 / 5000 metrics.
Thanks in advance.
