I’m using the Telegraf (v1.5.2) SNMP plugin to try and connect to an SNMP agent in order to store CPU and Interface utilisation metrics in an InfluxDB. However, I am seeing the following error when starting telegraf (Agent IP removed):
Feb 23 14:17:10 telegraf[1616]: 2018-02-23T14:17:10Z E! Error in plugin [inputs.snmp]: agent x.x.x.x: gathering table hosts: performing bulk walk for field hrProcessorLoad: OID not increasing: .1.3.6.1.2.1.25.3.3
This is the configuration I have for the snmp plugin (IP’s and passwords removed):
[[inputs.snmp]]
agents = [ "x.x.x.x" ]
timeout = "10s"
retries = 3
version = 3
community = "public"
sec_name = "xxx"
auth_protocol = "SHA" # Values: "MD5", "SHA", ""
auth_password = "xxx"
#sec_level = "authNoPriv" # Values: "noAuthNoPriv", "authNoPriv", "authPriv"
#context_name = ""
priv_protocol = "AES" # Values: "DES", "AES", ""
priv_password = "xxx"
name = "cpu"
[[inputs.snmp.field]]
name = "sysName"
oid = "SNMPv2-MIB::sysName"
is_tag = true
name = "hrDeviceDescr"
oid = "HOST-RESOURCES-MIB::hrDeviceDescr"
is_tag = true
[[inputs.snmp.table]]
name = "hosts"
inherit_tags = [ "hrDeviceDescr" ]
[[inputs.snmp.table.field]]
name = "hrProcessorLoad"
oid = "HOST-RESOURCES-MIB::hrProcessorTable"
is_tag = true
Has anyone seen this before or know what could be causing it? I know that there are ‘counters’ and ‘gauges’ when it comes to SNMP, and it seems like it is treating this as a counter (just a guess though). Any help would be appreciated.
Thanks.
