Hi everyone,
I am currently setting up Telegraf to use a Starlark processor script to add GeoLite2 geolocation data to my metrics. However, I keep encountering a syntax error at line 17, column 1, which says:
[telegraf] Error running agent: could not initialize processor processors.starlark: :17:1: got illegal token, want primary expression
Here is the relevant part of my telegraf.conf configuration file:
[[processors.starlark]]
source = '''
def apply(metric):
for point in metric:
if 'geoip' in point.tags:
city, country, latitude, longitude = geoip_lookup(point.tags['geoip'])
point.tags['city'] = city
point.tags['country'] = country
point.tags['latitude'] = latitude
point.tags['longitude'] = longitude
return metric
def geoip_lookup(ip):
db_path = '/usr/share/GeoIP/GeoLite2-City.mmdb'
geolite2 = Geolite2(db_path)
location = geolite2.lookup(ip)
return location['city'], location['country'], location['latitude'], location['longitude']
class Geolite2:
def __init__(self, db_path):
import geoip2.database
self.reader = geoip2.database.Reader(db_path)
def lookup(self, ip):
response = self.reader.city(ip)
return {
'city': response.city.name,
'country': response.country.name,
'latitude': response.location.latitude,
'longitude': response.location.longitude,
I’ve made sure that:
- The Starlark script is enclosed within triple single quotes (
'''). - The indentation is consistent within the script.
- There are no invisible characters or extra spaces at the beginning of the lines.
Despite these checks, I still get the same error. I also ran telegraf --config telegraf.conf --test, but the error persists.
If anyone has experienced a similar issue or can spot what might be going wrong, I would greatly appreciate your help.
Thank you!
