I happened to notice today that I have had a bug in my Telegraf agent section configuration for a long time that I hadn’t noticed before, and Telegraf hasn’t complained about this bug either.
It is about the precision parameter in the agent section.
The documentation says:
Valid values are
ns,us(orµs),ms, ands
So I had the following configuration in my agent section:
[agent]
interval = "1s"
precision = "ns"
The configuration works and there was no error message, but the precision parameter is ignored in this case and replaced by the value in interval. I noticed this behaviour, when I was working with higher resolution timestamps and wondered why all my timestamps were rounded to 1s after the output from Telegraf. ![]()
The correct configuration should be:
[agent]
interval = "1s"
precision = "1ns"
In my opinion, the documentation here is misleading, and if Telegraf doesn’t complain, you may not notice this error unless you look very closely at your output timestamps.
Also, the behavior of the precision parameter in an input plugin is different, there Telegraf complains.
This does not work:
[[inputs.file]]
precision = "ns"
[telegraf] Error running agent: Error loading config file xxx.conf: error parsing file, line 31:{363 455}: error parsing duration: time: invalid duration “ns”
This works and of course overrides the global precision setting of the agent section:
[[inputs.file]]
precision = "1ns"
@Anaisdg
IMHO this inconsistent behaviour of the precision parameter should be fixed in the agent section?
