Using the default “host” dashboard in Chronograf shows everything fine except network activity.
If I look at the query it says:
SELECT non_negative_derivative(max("bytes_recv"), 1s) AS "received", non_negative_derivative(max("bytes_sent"), 1s) AS "sent" FROM "telegraf"."autogen"."net" WHERE time > :dashboardTime: AND "host" = :host: GROUP BY time(:interval:) FILL(null)
and I get “Your query is syntactically correct but returned no results”
I have the standard input plugins enabled in telegraf and a quick query of the telegraf database says:
time host icmp_inaddrmaskreps icmp_inaddrmasks icmp_incsumerrors icmp_indestunreachs icmp_inechoreps icmp_inechos icmp_inerrors icmp_inmsgs icmp_inparmprobs icmp_inredirects icmp_insrcquenchs icmp_intimeexcds icmp_intimestampreps icmp_intimestamps icmp_outaddrmaskreps icmp_outaddrmasks icmp_outdestunreachs icmp_outechoreps icmp_outechos icmp_outerrors icmp_outmsgs icmp_outparmprobs icmp_outredirects icmp_outsrcquenchs icmp_outtimeexcds icmp_outtimestampreps icmp_outtimestamps icmpmsg_intype0 icmpmsg_intype3 icmpmsg_outtype3 icmpmsg_outtype5 icmpmsg_outtype8 interface ip_defaultttl ip_forwarding ip_forwdatagrams ip_fragcreates ip_fragfails ip_fragoks ip_inaddrerrors ip_indelivers ip_indiscards ip_inhdrerrors ip_inreceives ip_inunknownprotos ip_outdiscards ip_outnoroutes ip_outrequests ip_reasmfails ip_reasmoks ip_reasmreqds ip_reasmtimeout tcp_activeopens tcp_attemptfails tcp_currestab tcp_estabresets tcp_incsumerrors tcp_inerrs tcp_insegs tcp_maxconn tcp_outrsts tcp_outsegs tcp_passiveopens tcp_retranssegs tcp_rtoalgorithm tcp_rtomax tcp_rtomin udp_ignoredmulti udp_incsumerrors udp_indatagrams udp_inerrors udp_noports udp_outdatagrams udp_rcvbuferrors udp_sndbuferrors udplite_ignoredmulti udplite_incsumerrors udplite_indatagrams udplite_inerrors udplite_noports udplite_outdatagrams udplite_rcvbuferrors udplite_sndbuferrors
I note from this that there are no "bytes_recv" or "bytes_sent" data entities.
What am I missing?
