I have a Powershell script to collect data from a database server. The script runs fine in the OS, but fails with an exit code 1 then i run a telegraf test (telegraf --config telegraf.d\my_db_conf.conf --test --debug)
The output is:
2020-04-09T22:44:14Z E! [inputs.exec]: Error in plugin: exec: exit status 1 for command ‘powershell C:/Progra~1/telegraf
/telegraf.d/Scripts/script.ps1’: C:/Progra~1/telegraf/telegraf.d/Scripts/script.ps1 : The term …
I’d love to know what comes after “The term …” but I cannot capture that in the log or in the console.
The PowerShell script is:
$sql = @"
select ...
from sys.stats s
join ...
where ...
$dbs = Invoke-SqlCmd -Database master -Query "select name from sys.databases where name != 'tempdb'" -QueryTimeout 60;
$stats = @();
$results = @();
foreach($db in $dbs) {
$stats = Invoke-Sqlcmd -Database $db.name -Query $sql -QueryTimeout 60;
$stats | % {
$results += @{
database_name = $_.database_name;
schema_name = $_.schema_name;
table_name = $_.table_name;
stat_name = $_.stat_name;
stat_leading_column = $_.stat_leading_column;
last_udpdate_date = $_.last_updated;
rows = $_.rows;
unfiltered_rows = $_.unfiltered_rows;
rows_sampled = $_.rows_sampled;
modifications = $_.modification_counter;
update_threshold = $_.update_threshold;
$json_result = ConvertTo-Json -InputObject $results;
return $json_result;
Collector config is:
[[inputs.exec]]
interval = "6h"
commands = ["powershell C:/Progra~1/telegraf/telegraf.d/Scripts/script.ps1"]
timeout = "2m"
name_override = "sql_statistics"
There are multiple PowerShell scripts that use this same config (different name_override and different commands parameters) that work just fine.
