Hi, @Jay_Clifford
Happy start. Thank you for your support!
One more question, I want to know influx v 2.0 Can a large amount of data of the Internet of things be stored for a long time??
Is it convenient to talk about the single node storage bottleneck? At what level does my data need to be distributed
Hi @loneWolf666,
No worries at all! Would you mind opening a separate ticket for this and tag me there? Sorry for this just trying to keep our threads as close to the original topics as possible.
Hi, @loneWolf666,
A strange phenomenon happened on my server
##################### system resource telegraf config ##################################
organization = "trunkport"
bucket = "system_resource"
## The value of this tag will be used to determine the bucket. If this
## tag is not set the 'bucket' option is used as the default.
# bucket_tag = ""
## If true, the bucket tag will not be added to the metric.
# exclude_bucket_tag = false
## Timeout for HTTP messages.
# timeout = "5s"
## Additional HTTP headers
# http_headers = {"X-Special-Header" = "Special-Value"}
## HTTP Proxy override, if unset values the standard proxy environment
## variables are consulted to determine which proxy, if any, should be used.
# http_proxy = "http://corporate.proxy:3128"
## HTTP User-Agent
# user_agent = "telegraf"
## Content-Encoding for write request body, can be set to "gzip" to
## compress body or "identity" to apply no encoding.
# content_encoding = "gzip"
## Enable or disable uint support for writing uints influxdb 2.0.
# influx_uint_support = false
## Optional TLS Config for use on HTTP connections.
# tls_ca = "/etc/telegraf/ca.pem"
# tls_cert = "/etc/telegraf/cert.pem"
# tls_key = "/etc/telegraf/key.pem"
## Use TLS but skip chain & host verification
[[inputs.cpu]]
## Whether to report per-cpu stats or not
percpu = true
## Whether to report total system cpu stats or not
totalcpu = true
## If true, collect raw CPU time metrics
collect_cpu_time = false
## If true, compute and report the sum of all non-idle CPU states
report_active = false
[[inputs.disk]]
## By default stats will be gathered for all mount points.
## Set mount_points will restrict the stats to only the specified mount points.
# mount_points = ["/"]
## Ignore mount points by filesystem type.
ignore_fs = ["tmpfs", "devtmpfs", "devfs", "iso9660", "overlay", "aufs", "squashfs"]
[[inputs.diskio]]
## By default, telegraf will gather stats for all devices including
## disk partitions.
## Setting devices will restrict the stats to the specified devices.
# devices = ["sda", "sdb", "vd*"]
## Uncomment the following line if you need disk serial numbers.
# skip_serial_number = false
## On systems which support it, device metadata can be added in the form of
## tags.
## Currently only Linux is supported via udev properties. You can view
## available properties for a device by running:
## 'udevadm info -q property -n /dev/sda'
## Note: Most, but not all, udev properties can be accessed this way. Properties
## that are currently inaccessible include DEVTYPE, DEVNAME, and DEVPATH.
# device_tags = ["ID_FS_TYPE", "ID_FS_USAGE"]
## Using the same metadata source as device_tags, you can also customize the
## name of the device via templates.
## The 'name_templates' parameter is a list of templates to try and apply to
## the device. The template may contain variables in the form of '$PROPERTY' or
## '${PROPERTY}'. The first template which does not contain any variables not
## present for the device is used as the device name tag.
## The typical use case is for LVM volumes, to get the VG/LV name instead of
## the near-meaningless DM-0 name.
# name_templates = ["$ID_FS_LABEL","$DM_VG_NAME/$DM_LV_NAME"]
[[inputs.mem]]
# no configuration
[[inputs.net]]
## By default, telegraf gathers stats from any up interface (excluding loopback)
## Setting interfaces will tell it to gather these explicit interfaces,
## regardless of status.
# interfaces = ["eth0"]
## On linux systems telegraf also collects protocol stats.
## Setting ignore_protocol_stats to true will skip reporting of protocol metrics.
# ignore_protocol_stats = false
[[inputs.processes]]
# no configuration
[[inputs.swap]]
# no configuration
[[inputs.system]]
## Uncomment to remove deprecated metrics.
# fielddrop = ["uptime_format"]
################# iot monitor config.d dir telegraf ############################
bucket = "vehicle_info"
# bucket_tag = ""
# timeout = "5s"
## HTTP User-Agent
# INPUT PLUGINS #
[[inputs.mqtt_consumer]]
## Broker URLs for the MQTT server or cluster. To connect to multiple
## clusters or standalone servers, use a seperate plugin instance.
## example: servers = ["tcp://localhost:1883"]
## servers = ["ssl://localhost:1883"]
## servers = ["ws://localhost:1883"]
## servers = ["tcp://172.29.60.10:1883"]
servers = ["tcp://172.17.0.2:1883"]
## Topics that will be subscribed to.
topics = [
"/realtime-monitor/upload-info/+"
## Data format to consume.
## more about them here:
data_format = "json"
name_override = "test-list-2"
# Processor PLUGINS #
#credit goes to @srebhan
[[processors.starlark]]
source = '''
def apply(metric):
fields = ["wheel_angle", "wheel_odometer"]
for f in fields:
key_prefix = f+"_"
key_len = len(key_prefix)
keys = [x for x in metric.fields.keys() if x.startswith(key_prefix)]
keys = sorted(keys, key=lambda x: int(x[key_len:]))
values = [str(metric.fields.pop(k)) for k in keys]
new_value = "["+', '.join(values)+"]"
metric.fields[f] = new_value
return metric
[[processors.printer]]
But I found information about system resources in both buckets (vehicle_info)?? :hear_no_evil:
cpu mem ....... field Should there only be system resource buckets :weary:
Hi @loneWolf666,
not to worry what you need to do is filter those metrics out. So they are not processed through the starlark plugin or your output plugin to system resource. I have taken your config and applied an example but you will need to replace the <INSERT> with your own measurements name:
# bucket_tag = ""
# timeout = "5s"
## HTTP User-Agent
[[inputs.cpu]]
percpu = true
totalcpu = true
[[inputs.disk]]
[[inputs.diskio]]
## disk partitions.
## tags.
[[inputs.mem]]
# no configuration
[[inputs.net]]
# no configuration
[[inputs.swap]]
# no configuration
[[inputs.system]]
# bucket_tag = ""
# timeout = "5s"
## HTTP User-Agent
# INPUT PLUGINS #
topics = [
namepass = ["test-list-2"]
source = '''
def apply(metric):
for f in fields:
key_prefix = f+"_"
return metric
I added the namepass feature to your starlark plugin. I could not find your InfluxDB output plugin. You will also want to add a namedrop. To your influxDB output plugin which is writing to your system bucket. Here is any example:
[[outputs.influxdb_v2]]
namedrop = ["test-list-2"]
alias = "k8-2"
urls = ["${INFLUX_HOST}"]
token = "${INFLUX_TOKEN}"
organization = "${INFLUX_ORG}"
bucket = "bucket2"
This will drop any metrics with the measurement name
cool topic your working on BTW
Hi, @Jay_Clifford
Because my production environment decides to update conveniently, different mqtt topics use different telegraf configurations and put them in the telegraf. d directory and the data monitored by different topics and telegraf configurations enter different influxdb bucketsfor easy updating
I wonder if this plan can be realized? The problem with my local debugging is that I only sent a message to an mqtt topic, All telegraf conf received messages, causing all the data of the influx to be stored in buckets,It looks like mqtt topic topic matching mechanism fails
Hi, @Jay_Clifford
I added the configuration you prompted
namedrop = [“vehicle_info”, “system”]
name_override = “vehicle_info”
namepass = [“vehicle_info”]
but telegraf parser config error
############################# config ###############################
2021-12-08T09:29:11Z I! Starting Telegraf 1.20.4
2021-12-08T09:29:11Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf/telegraf.conf: Error parsing data: line 79: key `namedrop' is in conflict with line 4ed
2021-12-08T09:29:26Z I! Starting Telegraf 1.20.4
2021-12-08T09:29:26Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf/telegraf.conf: Error parsing data: line 79: key `namedrop' is in conflict with line 4ed
2021-12-08T09:29:54Z I! Starting Telegraf 1.20.4
2021-12-08T09:29:54Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf/telegraf.conf: Error parsing data: line 79: key `namedrop' is in conflict with line 4ed
2021-12-08T09:30:05Z I! Starting Telegraf 1.20.4
2021-12-08T09:30:05Z E! [telegraf] Error running agent: Error loading config file /etc/telegraf/telegraf.d/vehicle_info.conf: Error parsing data: line 79: key `namedrop' is in conflict with line 4ed
#################### Error reporting can only be seen to resolve conflicts #####################
########################### telegraf.conf ##################################
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
hostname = ""
omit_hostname = false
namedrop = ["vehicle_info", "vehicle_state"]
urls = ["http://192.168.16.2:8086"]
## Token for authentication.
token = "jovyuwtCCN59l2X3LA8Qz35A2em6wrlihj2E2P_meF0qN-UEWwcOEq4ZRmTU7ZVMCD-IL7_YvAwTdsasW-OocQ=="
# bucket_tag = ""
# timeout = "5s"
[[inputs.cpu]]
percpu = true
totalcpu = true
[[inputs.disk]]
[[inputs.diskio]]
## disk partitions.
## tags.
[[inputs.mem]]
# no configuration
[[inputs.net]]
# no configuration
[[inputs.swap]]
# no configuration
[[inputs.system]]
namepass = ["vehicle_state"]
############## telegraf.d / telegraf_info.conf ##################################
[agent]
interval = "10s"
flush_jitter = "10s"
precision = ""
## Log at debug level.
debug = true
## Override default hostname, if empty use os.Hostname()
hostname = ""
namedrop = ["vehicle_state", "system"]
bucket = "art_monitor"
topics = [
"/realtime-monitor/vehicle-info/+"
tag_keys = ["name"]
[[inputs.exec]]
## Commands array
commands = []
## measurement name suffix (for separating different commands)
name_suffix = "json"
json_strict = false
json_string_fields = ["name"]
name_override = "vehicle_info"
###################### telegraf.d/telegraf.conf ################
[agent]
interval = "10s"
## Default flushing interval for all outputs. Maximum flush_interval will be
## flush_interval + flush_jitter
precision = ""
hostname = ""
namedrop = ["vehicle_info","system"]
# INPUT PLUGINS #
topics = [
name_override = "vehicle_state"
namepass = ["vehicle_info"]
source = '''
def apply(metric):
for f in fields:
key_prefix = f+"_"
return metric
Hi @loneWolf666,
What is the parse error and which line?
Perhaps its because you have specified your agent config settings twice?
namedrop = [“vehicle_info”, “vehicle_state”]
I have three telegraf configurations, and name “name override” is performed on each mqtt data,
Two other configurations, name override, are excluded from each configuration
I do not see an issue with this line. It is the correct notation. Here is one of my examples which use name override plus routing:
# Telegraf Configuration
# Telegraf is entirely plugin driven. All metrics are gathered from the
# declared inputs, and sent to the declared outputs.
# Plugins must be declared in here to be active.
# To deactivate a plugin, comment out the name and any variables.
# Use 'telegraf -config telegraf.conf -test' to see what metrics a config
# file would generate.
# Environment variables can be used anywhere in this config file, simply surround
# them with ${}. For strings the variable must be within quotes (ie, "${STR_VAR}"),
# for numbers and booleans they should be plain (ie, ${INT_VAR}, ${BOOL_VAR})
# Global tags can be specified here in key="value" format.
[global_tags]
# dc = "us-east-1" # will tag all metrics with dc=us-east-1
# rack = "1a"
## Environment variables can be used as tags, and throughout the config file
# user = "$USER"
[agent]
interval = "5s"
## Rounds collection interval to 'interval'
## Telegraf will send metrics to outputs in batches of at most
## metric_batch_size metrics.
## This controls the size of writes that Telegraf sends to output plugins.
## Maximum number of unwritten metrics per output. Increasing this value
## allows for longer periods of output downtime without dropping metrics at the
## cost of higher maximum memory usage.
collection_jitter = "5s"
## Jitter the flush interval by a random amount. This is primarily to avoid
## large write spikes for users running a large number of telegraf instances.
## ie, a jitter of 5s and interval 10s means flushes will happen every 10-15s
flush_jitter = "5s"
## By default or when set to "0s", precision will be set to the same
## timestamp order as the collection interval, with the maximum being 1s.
## ie, when interval = "10s", precision will be "1s"
## when interval = "250ms", precision will be "1ms"
## Precision will NOT be used for service inputs. It is up to each individual
## service input to set the timestamp at the appropriate precision.
## Valid time units are "ns", "us" (or "µs"), "ms", "s".
precision = ""
hostname = ""
debug = true
quiet = false
# OUTPUT PLUGINS #
namepass = ["test"]
alias = "k8"
bucket = "bucket1"
namedrop = ["test"]
alias = "k8-2"
bucket = "bucket2"
# INPUT PLUGINS #
[[inputs.file]]
alias = "file-1"
files = ["./data/sample.json"]
tag_keys = ["Driver", "Channel", "Trace", "Notes", "Address", "Instrument"]
name_override = "test"
[[inputs.file]]
alias = "file-2"
name_override = "test2"
[[inputs.file]]
alias = "file-3"
name_override = "test3"
I checked your config again and this should not be there. Or maybe a copy-paste error. As there is no starlark function
