Hi there!
I have a Telegraf container that I’m using to capture streaming network telemetry and would like to use Telegraf to monitor port 57000 for bytes received. How would I go about doing that?
Thanks!!
Hi there!
Thanks!!
After some searching, I would suggest the iptables plugin: telegraf/plugins/inputs/iptables at master · influxdata/telegraf · GitHub
I haven’t done this so I can’t explain the details of how to do it, but from my brief reading, it looks like you can set an iptables rule (with a comment) for your port, and then the telegraf iptables plugin can monitor bytes associated with that rule.
If you get it working, please post a working example back. The community would benefit from this!
Will do!
Hi, did you manage to do that?
I need to do the same but I couldn’t find any way to get port/socket granularity measurements also with other alternatives.
Thank you
As per my knowledge,
To monitor port 57000 with Telegraf, add this to your telegraf.conf:
toml
Copy code
[[inputs.socket_listener]]
service_address = "udp://:57000"
data_format = "influx"
This config listens on port 57000 for incoming UDP traffic.
I hope this will help you ,
Thank you
