I’m using Telegraf(which is running on Raspberry-pi 3B) to collect data via inputs.mqtt_consumer and pushing data into influxdb (which is on server) using output.influxdb.
Everything is working as per expectation and Telegraf is able to push mqtt data into influxdb.
So, now if i update any of the plugin and restarts telegraf, modifications becomes successfully active and everything works fine.
But, as soon as I turn off my Raspberry-Pi and power-on/restarts it, all these modifications are lost.
For example :
- I have current inputs.mqtt_consumer in telegraf.conf (/etc/telegraf/telegraf.conf) which looks like:
[[inputs.mqtt_consumer]]
# ## MQTT broker URLs to be used. The format should be scheme://host:port,
# ## schema can be tcp, ssl, or ws.
servers = ["tcp://localhost:1883"]
# ## MQTT QoS, must be 0, 1, or 2
qos = 2
# ## Topics to subscribe
topics = [ "Sensor/temperature/#" ]
- Now if i change, qos or update topics.
qos = 1
topics = [ "Sensor/pressure/#" ]
and restarts telegraf using
sudo systemctl restart telegraf
3. telegraf works correctly with new qos value 1 and new topic “Sensor/pressure/#”.
4. Now, if i restarts raspberry-pi, all these changes in telegraf.conf are lost. It looks like exactly as same as before, which is not expected:
qos = 2
There are no any other instances of telegraf.conf on rasp-pi.
Thanks in advance and Looking forward to hear from you.
