Iam using Telegraf as Daemonset in my Kubernetes environment and for some reason it shows this error
[inputs.kubernetes] Error in plugin: Error parsing response: json: cannot unmarshal number 9223372036854775808 into Go struct field VolumeMetrics.pods.volume.capacityBytes of type int64
The Number is exatly one byte bigger than what int64 can handle so iam guessing it is a bug because we dont have volumes of this size.
Any insight where the error could lie would be much appreciated
This is my config
[agent]
collection_jitter = "0s"
debug = false
flush_interval = "10s"
flush_jitter = "5s"
hostname = "$HOSTNAME"
interval = "10s"
logfile = ""
metric_batch_size = 1000
metric_buffer_limit = 10000
omit_hostname = false
precision = ""
quiet = true
round_interval = true
[[inputs.kubernetes]]
url = "https://$HOSTIP:10250"
bearer_token = "/var/run/secrets/kubernetes.io/serviceaccount/token"
insecure_skip_verify = true
fieldpass = ["cpu_usage_nanocores"]
[[outputs.influxdb_v2]]
urls = xxxx
token = xxxx
organization = xxxx
bucket = xxxxx
namepass =xxxxx
