I’ve installed the Telegraf 1.25.2 helm chart from telegraf 1.8.26 · helm/influxdata into my Google Cloud Platform (GCP) kubernetes cluster but the startup fails with a “su-exec: telegraf: Operation not permitted” error.
The only warning I saw during installation was about letting auto-pilot pick the sizes for the pod VMs. It didn’t seem related to the su-exec error.
Here is the command I ran to deploy the chart and its output:
$ helm upgrade --install telegraf influxdata/telegraf
Release "telegraf" does not exist. Installing it now.
W0308 13:42:40.493507 98179 warnings.go:70] Autopilot set default resource requests for Deployment metrics/telegraf, as resource requests were not specified. See g.co gke autopilot-defaults
LAST DEPLOYED: Wed Mar 8 13:42:36 2023
NAMESPACE: metrics
STATUS: deployed
REVISION: 1
TEST SUITE: None
NOTES:
To open a shell session in the container running Telegraf run the following:
kubectl exec -i -t --namespace metrics $(kubectl get pods --namespace metrics -l app.kubernetes.io/name=telegraf -o jsonpath='{.items[0].metadata.name}') /bin/sh
To view the logs for a Telegraf pod, run the following:
kubectl logs -f --namespace metrics $(kubectl get pods --namespace metrics -l app.kubernetes.io/name=telegraf -o jsonpath='{ .items[0].metadata.name }')
The kubectl commands afterwards fail because no pod is successfully started:
$ kubectl exec -i -t --namespace metrics $(kubectl get pods --namespace metrics -l app.kubernetes.io/name=telegraf -o jsonpath='{.items[0].metadata.name}') /bin/sh
kubectl exec POD COMMAND is DEPRECATED and will be removed in a future version. Use kubectl exec POD -- COMMAND instead.
error: unable to upgrade connection: container not found ("telegraf")
$ kubectl logs -f --namespace metrics $(kubectl get pods --namespace metrics -l app.kubernetes.io/name=telegraf -o jsonpath='{ .items[0].metadata.name }')
I only found docker issues when googling for su-exec errors. They didn’t seem related to kubernetes.
Has anyone seen this error in k8s before?
