I’m using [[inputs.http]] to collect VPN status information using an https API call that returns data in JSON format.
The following is a sample JSON input:
JSON input
"user": {
"login": "myusername",
"register_date": "2018-07-14 22:50:53",
"register_unix": "1531608653",
"premium": true,
"expiration_unix": "1586906223",
"expiration_date": "2020-04-14 23:17:03",
"expiration_days": 375,
"last_attempt_unix": "1554475586",
"posts": "0",
"last_post": null,
"last_visit_unix": "1554387254",
"last_activity_unix": "1554446767",
"credits": 0,
"credit": [],
"connected": true
"sessions": [
"device_name": "Server",
"device_description": "OVPN Outgoing",
"vpn_ip": "10.23.44.175",
"vpn_ipv4": "10.23.44.175",
"vpn_ipv6": "fde6:7a:7d20:132c::10ad",
"exit_ip": "64.45.139.43",
"exit_ipv4": "64.45.139.43",
"exit_ipv6": "2645:1f50:2000:25:848d:e3b5:8bc8:34f",
"entry_ip": "64.45.139.42",
"entry_ipv4": "64.45.139.42",
"entry_ipv6": "2645:1f50:2000:25:e46c:8e0d:ee6b:38d7",
"server_name": "Muscat",
"server_country": "United States",
"server_country_code": "us",
"server_continent": "America",
"server_location": "Dallas, Texas",
"server_bw": "1000",
"bytes_read": "1744743821329",
"bytes_write": "936713144587",
"connected_since_date": "2019-03-08 05:04:36",
"connected_since_unix": "1552021476",
"speed_read": "537.1167",
"speed_write": "14872.4167"
"device_name": "Desktop",
"device_description": "Desktop",
"vpn_ip": "10.29.204.219",
"vpn_ipv4": "10.29.204.219",
"vpn_ipv6": "fde6:7a:7d20:19cc::10d9",
"exit_ip": "193.37.254.19",
"exit_ipv4": "193.37.254.19",
"exit_ipv6": "2a0d:5600:2:6:f362:ba43:29f3:b8a",
"entry_ip": "193.37.254.18",
"entry_ipv4": "193.37.254.18",
"entry_ipv6": "2a0d:5600:2:6:994d:de38:fedf:47a7",
"server_name": "Chalawan",
"server_location": "Phoenix, Arizona",
"bytes_read": "0",
"bytes_write": "0",
"connected_since_date": "2019-04-05 14:46:25",
"connected_since_unix": "1554475585",
"speed_read": null,
"speed_write": null
"connection": {
"result": "ok"
The fields I want are:
expiration_days
device_description
exit_ipv4
exit_ipv6
bytes_read
bytes_write
speed_read
speed_write
The following are the relevant lines from my .conf file:
tag_keys = ["device_description"]
name_override = "VPN"
json_query = "sessions"
json_string_fields = [
"exit_ipv4",
"exit_ipv6"
data_format = "json"
The telegraf --test command returns exit_ipv4 and exit_ipv6 for tags ‘OVPN Outgoing’ and ‘Desktop’. It took me a while to figure out why nothing else was being returned – my numbers all have quotes around them making them strings.
To make the data more readable in Grafana, I don’t want a 13-digit number for bytes_read for example, and would like to set units within Grafana to ‘bytes’ so that it will display ‘1.74 TB’ instead of ‘1744743821329’.
Is there a way to convert the string format numbers into an actual number?
Interestingly while I was learning and experimenting with json input, I had my desired fields defined as tag_keys and bytes_read for example was treated as a number by Grafana. The problem is this only works when there is one device in sessions (Server is connected 24/7) and once I add a session (Desktop) the parsing gets confused.
