i want to stat telegraf for importing excel data into infuxdb but after installing the telegraf im having this error when i check the status:
aexlab@dennis-HP-ZBook-15:~$ sudo systemctl status telegraf
[sudo] password for aexlab:
● telegraf.service - Telegraf
Loaded: loaded (/lib/systemd/system/telegraf.service; enabled; vendor pres>
Active: failed (Result: exit-code) since Wed 2023-07-19 16:00:36 CEST; 14m>
Docs: GitHub - influxdata/telegraf: The plugin-driven server agent for collecting & reporting metrics.
Process: 19841 ExecStart=/usr/bin/telegraf -config /etc/telegraf/telegraf.c>
Main PID: 19841 (code=exited, status=1/FAILURE)
Jul 19 16:00:36 dennis-HP-ZBook-15 systemd[1]: telegraf.service: Scheduled rest>
Jul 19 16:00:36 dennis-HP-ZBook-15 systemd[1]: Stopped Telegraf.
Jul 19 16:00:36 dennis-HP-ZBook-15 systemd[1]: telegraf.service: Start request >
Jul 19 16:00:36 dennis-HP-ZBook-15 systemd[1]: telegraf.service: Failed with re>
Jul 19 16:00:36 dennis-HP-ZBook-15 systemd[1]: Failed to start Telegraf.
i have uncommented important points in config file as well. can anyone help please.
