I’m trying to configure the snmp input for telegraf to pull metrics from my F5 Big IP load balancers. I am able to see all the OID utilizing snmpwalk, but for whatever reason i am not having the same success when configuring the snmp input.
# snmpwalk -v2c -c <community string> <big ip - ip> RFC1213-MIB::sysName.0
SNMPv2-MIB::sysName.0 = STRING: <big ip hostname>
example snmpwalk command/output - i ran each and every oid i configured to verify it was returning a value without error
initial config
[[inputs.snmp]]
agents = ["<big ip - ip>"]
version = 2
community = "<community string>"
interval = "60s"
timeout = "10s"
retries = 3
name = "snmp"
[[inputs.snmp.field]]
name = "hostname"
oid = "RFC1213-MIB::sysName.0"
is_tag = true
name = "F5_httpRequests"
oid = "F5-BIGIP-SYSTEM-MIB::sysGlobalStat.56"
name = "F5_client_connections"
oid = "F5-BIGIP-SYSTEM-MIB::sysGlobalStat.8"
name = "F5_client_bytes_in"
oid = "F5-BIGIP-SYSTEM-MIB::sysGlobalStat.60"
initial config output
# telegraf --test | grep snmp
2018/06/02 00:54:56 I! Using config file: /etc/telegraf/telegraf.conf
* Plugin: inputs.snmp, Collection 1
i modified the config to and i would get an output of some kind, but it does not contain all of the data in the config and the format seems off. it was the best i was able to achieve though…
adjusted config
[[inputs.snmp]]
version = 2
interval = "60s"
timeout = "10s"
retries = 3
name = "snmp"
name = "hostname"
adjusted config output
2018/06/02 00:58:15 I! Using config file: /etc/telegraf/telegraf.conf
> snmp,agent_host=172.22.15.71,host=ops-worker-001.prod.dc3 hostname="lb01.prod.dc3" 1527901098000000000
I see my first mistake in the config not being nested under the main [[inputs.snmp]]… what i don’t get is why can’t i tag anything or get all of the outputs? i tried making tables and things of that nature… i even used the example config (verifying all the oids returned values) and that didn’t even work.
example config
[[inputs.snmp]]
agents = [ "host.example.com" ]
version = 2
community = "public"
name = "hostname"
is_tag = true
name = "uptime"
oid = "F5-BIGIP-SYSTEM-MIB::sysSystem.6"
# IF-MIB::ifTable contains counters on input and output traffic as well as errors and discards.
[[inputs.snmp.table]]
name = "interface"
inherit_tags = [ "hostname" ]
oid = "IF-MIB::ifTable"
# Interface tag - used to identify interface in metrics database
[[inputs.snmp.table.field]]
name = "ifDescr"
oid = "IF-MIB::ifDescr"
is_tag = true
# IF-MIB::ifXTable contains newer High Capacity (HC) counters that do not overflow as fast for a few of the ifTable counters
name = "interface"
oid = "IF-MIB::ifXTable"
name = "ifDescr"
is_tag = true
# EtherLike-MIB::dot3StatsTable contains detailed ethernet-level information about what kind of errors have been logged on an interface (such as FCS error, frame too long, etc)
name = "interface"
oid = "EtherLike-MIB::dot3StatsTable"
name = "ifDescr"
is_tag = true
I’m quite certain i am missing something small and silly, but i need more eyes on this to help me find that.
full telegraf config
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
debug = true
quiet = false
logfile = ""
hostname = ""
omit_hostname = false
# Configuration for sending metrics to InfluxDB
[[outputs.influxdb]]
urls = ["http://influxdb-server:8086"]
database = "telegraf"
# Read metrics about cpu usage
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
report_active = false
# Read metrics about disk usage by mount point
[[inputs.disk]]
ignore_fs = ["tmpfs", "devtmpfs", "devfs"]
# Read metrics about disk IO by device
[[inputs.diskio]]
# no configuration
# Get kernel statistics from /proc/stat
[[inputs.kernel]]
# no configuration
# Read metrics about memory usage
[[inputs.mem]]
# no configuration
# Get the number of processes and group them by status
[[inputs.processes]]
# no configuration
# Read metrics about swap memory usage
[[inputs.swap]]
# no configuration
# Read metrics about system load & uptime
[[inputs.system]]
# no configuration
# Collect bond interface status, slaves statuses and failures count
[[inputs.bond]]
# Read metrics about docker containers
[[inputs.docker]]
endpoint = "unix:///var/run/docker.sock"
gather_services = false
container_names = []
container_name_include = []
container_name_exclude = []
timeout = "5s"
perdevice = true
total = false
docker_label_include = []
docker_label_exclude = []
# Read stats from one or more Elasticsearch servers or clusters
[[inputs.elasticsearch]]
servers = ["http://es-cluster-nodes:9200"]
http_timeout = "5s"
local = false
cluster_health = false
cluster_stats = false
# Monitor disks' temperatures using hddtemp
[[inputs.hddtemp]]
# Read InfluxDB-formatted JSON metrics from one or more HTTP endpoints
[[inputs.influxdb]]
urls = [
"http://influxdb-server:8086/debug/vars"
timeout = "5s"
# Monitor sensors, requires lm-sensors package
[[inputs.sensors]]
# Read metrics from storage devices supporting S.M.A.R.T.
[[inputs.smart]]
use_sudo = true
[[inputs.snmp]]
version = 2
interval = "60s"
timeout = "10s"
retries = 3
name = "snmp"
name = "hostname"
if there is something else impacting the snmp config i don’t know… i removed all of that stuff except the base config and got the same results.
