I’m using telegraf on an OPNsense system (FreeBSD 11.1-RELEASE-p6). This system has six ethernet interfaces total. One interface, em0, seems to be sending bad data into influxdb for bytes_sent. The rest of the interfaces appear to be working as expected, and bytes_recv also appears to work correctly in this interface.
I have tried creating a new influx database, but it seems like it is probably on the telegraf side.
I also saw this same issue on a pfSense system, which is also on FreeBSD.
> SELECT "bytes_sent" FROM "net" WHERE ("interface" = 'em0' AND "host" =~ /^opnsense-1$/) AND time >= now() - 1m
time bytes_sent
1520636495000000000 8628839
1520636505000000000 8628839
1520636515000000000 8628839
1520636525000000000 8628839
1520636535000000000 8628839
1520636545000000000 8628839
% netstat -I em0 -b
Name Mtu Network Address Ipkts Ierrs Idrop Ibytes Opkts Oerrs Obytes Coll
em0 1500 <Link#1> 00:0c:29:30:b0:13 77935 0 0 14337154278 52496 0 8628839 0
em0 - <1.2.3.4>/ <1.2.3.4> 19197387 - - 10626667850 34283153 - 17564605980 -
% telegraf --input-filter net --test | grep em0
> net,interface=em0,host=opnsense-1 err_out=0i,drop_in=0i,drop_out=0i,bytes_sent=8628839i,bytes_recv=14906910189i,packets_sent=52496i,packets_recv=77935i,err_in=0i 1520637784000000000
% cat telegraf.conf
[global_tags]
[agent]
interval = "10s"
round_interval = false
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_jitter = "0s"
precision = ""
debug = false
quiet = true
logfile = "/var/log/telegraf.log"
hostname = "opnsense-1"
omit_hostname = false
[[outputs.influxdb]]
urls = ["https://influxdb:8086"]
database = "telegraf"
retention_policy = ""
write_consistency = "any"
timeout = "5s"
username = "<redacted>"
password = "<redacted>"
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
[[inputs.disk]]
[[inputs.diskio]]
[[inputs.mem]]
[[inputs.processes]]
[[inputs.swap]]
[[inputs.system]]
[[inputs.net]]
I get the same issue using collectd. This seems to be a FreeBSD thing.
daniel
3
We use gopsutil to gather the info, here is the function we call. Looks like it runs netstat -ibdnW and takes the first entry for each interface, if we can come up with a better method we could open a pull request to have it modified.
Interesting. Running netstat -ibdnW shows me that while the IPV4 counters increment normally, the link counters do not. Both Opkts and Obytes never change, while the IPv4 counters do.
% netstat -ibdnW
Name Mtu Network Address Ipkts Ierrs Idrop Ibytes Opkts Oerrs Obytes Coll Drop
em0 1500 <Link#1> 00:0c:29:30:b0:13 29895 0 0 17052983977 46293 0 41289211 0 0
em0 - xx.xxx.xxx.x/xx xx.xxx.xxx.xxx 12001664 - - 15325736646 16406071 - 1390516328 - -
<snip>
Odder still, there are more than half a dozen interfaces in this system, all working normally except for this one. I’ll keep poking at it, and thank you for pointing me at the collection method.
sco01
5
I ran into the same issue today on OPNsense 18.7 (FreeBSD 11.1-RELEASE-p11). em0 is reporting the same value for bytes_sent over and over.
netstat -ibdnW yields the same result as for @kendokan. The other interface on the same host is reporting the correct value.
