Telegraf Input Exec and Piped command
Hy everyone i try to use this “piped command” on the exec input :
but i have this error :
2018-04-04T12:53:50Z E! Error in plugin [inputs.exec]: exec: exit status 2 for command ‘curl --user admin:password http:// 192.168.1.21/ISAPI/System/status -s | xml_grep ‘cpuUtilization’ --text_only’: curl: option --text_only: is unknown…
Command works well in CLI :
[root@influxDB ~]# curl --user admin:password http:// 192.168.1.21/ISAPI/System/status -s | xml_grep ‘cpuUtilization’ --text_only
43
On my telegraf.conf :
[[inputs.exec]]
commands = [“curl --user admin:password http:// 192.168.1.21/ISAPI/System/status -s | xml_grep ‘cpuUtilization’ --text_only”]
name_override = “Hikvision_cpu”
data_format = “value”
data_type = “integer”
Telegraf doesn’t support pipes in the exec input.
You can add your command to a shell script and execute that instead. Make sure that you set the permissions on the script so that the telegraf user can execute them.
i think it would make our lives a lot easier if telegraf could support using pipes in the exec plugin; especially for single value extractions like server power load via ipmi-dcmi etc.
For simple tasks it ought to work if you run the command in a shell:
commands = ['/bin/bash -c "curl ... | grep foo"']
Yay! thanks @daniel ! it’s a little awkward with the toml string escapes, but it does work :slight_smile: thanks!
