Hi guys,
What I have on my InfluxDB, Telegraf and MySQL sides:
One MySQL server - 127.0.0.1:3306
5 databases:
test_db1
test_db2
test_db5
Tried:
servers = [“root:root@tcp(127.0.0.1:3306)/?tls=false”]
table_schema_databases= [“database1”,…,“database2”]
sudo service telegraf restart - OK
telegraf log shows:
tail -f /var/log/telegraf/telegraf.log
2017-12-13T23:53:10Z I! Starting Telegraf v1.4.5
2017-12-13T23:53:10Z I! Loaded outputs: influxdb
2017-12-13T23:53:10Z I! Loaded inputs: inputs.processes inputs.swap inputs.cpu inputs.disk inputs.mem inputs.system inputs.mysql inputs.diskio inputs.kernel
2017-12-13T23:53:10Z I! Tags enabled: host=mysql-example-com
2017-12-13T23:53:10Z I! Agent Config: Interval:10s, Quiet:false, Hostname:“host=mysql-example-com
”, Flush Interval:10s
2017-12-14T00:09:05Z I! Starting Telegraf v1.4.5
2017-12-14T00:09:05Z I! Loaded outputs: influxdb
2017-12-14T00:09:05Z I! Loaded inputs: inputs.system inputs.mysql inputs.disk inputs.kernel inputs.mem inputs.processes inputs.swap inputs.cpu inputs.diskio
2017-12-14T00:09:05Z I! Tags enabled: host=mysql-example-com
2017-12-14T00:09:05Z I! Agent Config: Interval:10s, Quiet:false, Hostname:“host=mysql-example-com
So far so good.
But InfluxDB console doesn’t show any database1 or database2 tag keys for measurement ‘mysql’.
Whats wrong with my configuration?
