Hi, I’m using a raspberry with Ubuntu 22.04.4 LTS.
I can’t start telegraf with the command " systemctl start telegraf ".
I’ve already made sure that I’ve edited the configuration file correctly.
The two plugins I’m using are [inputs.modbus] and [outputs.influxdb_v2].
The output of journalctl -eu telegraf is the following:
telegraf.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: telegraf.service: Failed with result ‘exit-code’.
systemd[1]: Failed to start Telegraf.
systemd[1]: telegraf.service: Consumed 1.164s CPU time.
systemd[1]: telegraf.service: Scheduled restart job, restart counter is at 2.
systemd[1]: Stopped Telegraf.
systemd[1]: Starting Telegraf…
telegraf[6699]: time=“2024-08-09T10:53:32+02:00” level=warning msg=“DBUS_SESSION_BUS_ADDRESS envvar looks to be not set, this can lead to runaway dbus-daemon processes. To avoid this, set envvar DBUS_SESSION_BUS_ADDRESS=$XDG_RUNTIME_DIR/bus (if it exists) or DBUS_SESSION_BUS_ADDRESS=/dev/null.” func=“gosnowflake.(*defaultLogger).Warn” file=“log.go:244”
telegraf[6699]: 2024-08-09T08:53:32Z I! Loading config: /etc/telegraf/telegraf.conf
telegraf[6699]: 2024-08-09T08:53:32Z E! [telegraf] Error running agent: no outputs found, did you provide a valid config file?
systemd[1]: telegraf.service: Main process exited, code=exited, status=1/FAILURE
How can i fix it?
From the logs:
The default config does not come with an output defined. You need to define an output.
Are you sure you added them correctly and fully?
Hi, thank you very much for your reply! I think I compiled the plugins correctly because if I start telegraf with the command " telegraf --config telegraf.conf " , everything works and I can also view the graphs on Influx.
Excuse me for the question, i’m new, what do you mean by " default config" ?
You are running telegraf as a service under systemd, that means by default it will run the command in the service file. This command is:
/usr/bin/telegraf --config /etc/telegraf/telegraf.conf --configuration-directory /etc/telegraf/telegraf.conf.d
You have to tell Telegraf which config file to use, and when run as a service it will use the above by default. It seems likely that you have not updated them.
When I run the command “sudo systemctl edit telegraf” and enter “ExecStart=/usr/bin/telegraf --config /etc/telegraf/telegraf.conf --configuration-directory /etc/telegraf/telegraf.conf.d”, after having saved it tells me " Editing “/etc/systemd/system/telegraf.service.d/override.conf” canceled: temporary file is empty."
What am I doing wrong?
You should not need to edit service file, that is already the default! What you need to edit is the file at /etc/telegraf/telegraf.conf
Again, going back to your original error message, the configuration file that telegraf is trying to read, /etc/telegraf/telegraf.conf does not have any outputs. You have some telegraf.conf file somewhere that you have not specified and need to update /etc/telegraf/telegraf.conf to have the same config or replace it with your file.
Thank you very much JPower, now everything is clear!
I had two telegraf.conf files: one updated and one not!
Thanks for your time
