Hello Community,
I got a problem trying to add a new feature to my grafana deployment, basically i receive this error msg every time i try to debuging:
E! [inputs.exec] Error in plugin: exec: exit status 120 for command ‘/bin/python3.9 /opt/telegraf/api/iaas/nxapi/nxos.py -u -p -n router-fqdn --show_version’
The script can be executed without errors detected with the telegraf user:
[root@vm nxapi]# sudo -u telegraf /bin/python3.9 /opt/telegraf/api/iaas/nxapi/nxos.py -u -p -n router-fqdn --show_version
nxos_system,hostname=router-fqdn biosversion=“3.1.0”,kickstartversion=“7.3(3)D1(1)”,systemversion=“7.3(3)D1(1)”,chassisid=“Nexus7700 C7706 (6 Slot) Chassis”,nxosfilename=“bootflash:///n7700-s2-dk9.7.3.3.D1.1.bin”,moduleid=“Supervisor Module-2”,modulesn=“omited”
Looks like not to be a proble with the directory permitions:
[root@vm nxapi]# ll
total 12
-rwxr-xr-x. 1 telegraf telegraf 2316 Sep 16 13:21 README.md
drwxr-xr-x. 3 telegraf telegraf 64 Sep 18 15:25 commands
drwxr-xr-x. 3 telegraf telegraf 51 Sep 18 15:30 common
drwxr-xr-x. 3 telegraf telegraf 50 Oct 8 09:17 controllers
drwxr-xr-x. 3 telegraf telegraf 21 Sep 16 13:21 hardware
-rwxrwxr-x. 1 telegraf telegraf 5575 Oct 8 09:03 nxos.py
drwxr-xr-x. 3 telegraf telegraf 48 Oct 8 09:20 view
[root@cvs1pap70 nxapi]#
Any idea? i even try to enable the telegraf debug mode but no extra errors are showing
[root@cvs1pap70 nxapi]# cat /opt/telegraf/telegraf.conf | grep debug | grep -v “#”
debug = true
Module exec file:
[root@vm nxapi]# cat /opt/telegraf/telegraf.d/iaas/routers_api.conf
[[inputs.exec]]
commands = [“/bin/python3.9 /opt/telegraf/api/iaas/nxapi/nxos.py -u -p -n --show_version”]
interval = “5m”
timeout = “30s”
data_format = “influx”
Thank for your help and support!
