Hello, and thank you in advance for any help you may provide.
I have influxdb and telegraf running and collecting data.
When collecting CPU data of the physical machine through telegraf, the collected data are all garbled in the log
like that nable to parse '�Uz%': missing fields tn8�[Z �h>�|,>�d&"���m�ج���sc�7S!���L�%�}�I9"
9:���J����y���O8"���)+�’���kIyآVd��D;‘m���e��U��t]-�)�T��}�ڮ֬n�{��l6>fʔ,����1&��R;M����[+�ՙ’JO���P��Kh��V��t2ɣ�����e�B���t�2=(�X�l���
��^�)�IT� Cr�9���f�NG$!0���A� Y�T��;uHE
�ΐ�"�G� ]L��sv �^�MJ�?kE�U4�:�2���A"�����X.���3�*$�J��8B�TG�O'C�D�-BЂ��v���H': invalid field format unable to parse '2/��b-�� ��r6yL���jB��!
�q’: invalid field format
unable to parse ’
r9�<&U�]ڔ� O�’: invalid field format���iu��Sΐi���"-
unable tA��B�ABD 3�"$+�i^�?����T�������Y�=���pgV��+�Q�h�����v���s��HV��=�}%\�b��dF"u�WIb�ut2���e�b�2�B?��"�����a���p�}�8_,X������&��S�b�iĂ��Ԍڧ�D�I,W$�)�@��1 �K( a���-���Haڲd���zp6����.���!LO��'V:Q�e': invalid boolean unable to parse '��Ò����.��qocv�Pu�3 >�����3�Hn�M5] �,�V��2D�]�8^N����)��F��C��>�N2�ӧ)��l3��x�í��.A:��e�"*"(�꘨h�)�f{D�Ⲗ�> ��g�q�!��fnBu��I�t@��&D;��J9�|�,�4Q� a��P���D�H�-ı���P��r�«!����+���^�1�:����o�-1����9�]�C�(�+��’: missing tag value
unable to parse '11��q
���(TH
Ul%�N��L�@0'�G�}�؎ ���ͤ�� ��"TŪc��^V�;���[e�W�R�P@�a� �)<1w ���J��z��Pe��G�1u2K5� ��t�OsIR�4 ������R��0,Hd�iNn|9��L��z�9CdB��σ&F�zR@4�YY$��
��.�’: invalid field format
unable to parse '�
': missing fields
2021-11-01T07:41:53Z E! [agent] Error writing to outputs.influxdb: could not write any address
2021-11-01T07:41:53Z I! [agent] Stopping running outputs`
This is my configuration
[global_tags]
[agent]
interval = "10s"
round_interval = true
metric_batch_size = 1000
metric_buffer_limit = 10000
collection_jitter = "0s"
flush_interval = "10s"
flush_jitter = "0s"
precision = ""
quiet = false
logtarget = "file"
logfile = "/var/log/telegraf/telegraf.log"
hostname = "test1"
omit_hostname = false
[[outputs.influxdb]]
urls = ["http://10.20.5.8:8086"]
database = "iaas_test"
database_tag = "iaas_test"
skip_database_creation = true
user_agent = "telegraf"
[[inputs.cpu]]
percpu = true
totalcpu = true
collect_cpu_time = false
report_active = false
[[inputs.mem]]
