on linux, usually I used the command iostat and sar -d.
on sar -d I use the value service time.
I don’t find how caculate servicetime from diskio.
any ideas ?
any ideas ?
Is this the field you are using from sar?:
man sar:
svctm
The average service time (in milliseconds) for I/O
requests that were issued to the device. Warning! Do not
trust this field any more. This field will be removed in
a future sysstat version.
Perhaps you can replace this with iotime(field 10 below) and iops_in_progress(field 9).
/usr/src/linux/Documentation/iostats.txt:
Field 9 -- # of I/Os currently in progress
The only field that should go to zero. Incremented as requests are
given to appropriate struct request_queue and decremented as they finish.
Field 10 -- # of milliseconds spent doing I/Os
This field increases so long as field 9 is nonzero.
