Is there a way to set once
[[inputs.mqtt_consumer]]
servers = ["tcp://localhost:1883"]
username = "user"
password = "pass"
connection_timeout = "30s"
qos = 0
# and other parameters when necessary
as defaults so that I wouldn’t need to repeat those in all different inputs? Usually this is the same basic configuration for most of the inputs.mqtt_consumers. Only changing part is the topics subscribed for the input and data_format, data_type, parsing and processing that varies depending on the topic.
