After a certain threshold of metrics, telegraf starts to crash and I get following logs:
2021-02-15T12:49:26Z I! Starting Telegraf 1.11.0
2021-02-15T12:49:26Z I! Loaded inputs: kernel swap system net netstat cpu disk diskio mem processes jolokia2_agent procstat statsd
2021-02-15T12:49:26Z I! Loaded aggregators:
2021-02-15T12:49:26Z I! Loaded processors:
2021-02-15T12:49:26Z I! Loaded outputs: prometheus_client
2021-02-15T12:49:26Z I! Tags enabled: cloud_provider=aws host=***
2021-02-15T12:49:26Z I! [agent] Config: Interval:15s, Quiet:false, Hostname:"***", Flush Interval:4s
2021-02-15T12:49:26Z W! [inputs.statsd] The parse_data_dog_tags option is deprecated, use datadog_extensions instead.
2021-02-15T12:49:26Z I! [inputs.statsd] Statsd UDP listener listening on: [::]:8130
2021-02-15T12:49:26Z I! [inputs.statsd] Started the statsd service on :8130
2021-02-15T12:55:26Z I! [inputs.statsd] Stopping the statsd service
2021-02-15T12:55:26Z I! Stopped Statsd listener service on :8130
2021-02-15T12:55:26Z I! [agent] Hang on, flushing any cached metrics before shutdown
2021-02-15T12:55:26Z I! Starting Telegraf 1.11.0
Host: ubuntu-14
I even tried with 1.17.2 and same result. A lot of metrics are getting written down to statsd via datadog emitter(udp)
What is causing these restarts ?
