I have a flux task that monitors windows devices and should send alerts according to configured thresholds.In my case the thresholds are if r._value > 92.0 then "crit" else if r._value > 80.0 then "warn" else "ok",
However, I keep getting wrong alerts. I get critical alert at 0%, normal at 62% or warn at 3%. And later on for example I get critical at 56% and normal at 0%. I can’t find any pattern in the alerts and can’t figure out what the problem is. I have more tasks like this one, just with different measurements, and everyone besides this one works fine. I’ll put the whole code at the bottom
import "http"
import "influxdata/influxdb/tasks"
import "influxdata/influxdb/monitor"
import "influxdata/influxdb/v1"
import "math"
import "date"
import "json"
import "internal/debug"
option task = {name: "", every: 5m, timeout: 1m}
msg_grp = ""
_check_name = ""
FLUCTUATION_CAP = 4
ALERTNAME = "win_cpu"
MEASUREMENT = "win_cpu"
FIELD = "Percent_Processor_Time"
endpoint =
http.endpoint(url: "")(
mapFn: (r) => {
body = {r with _version: 1}
alert_msg = "Percent processor time on ${r.host} is ${math.round(
x: float(v: r.Percent_Processor_Time) * 100.0,
) / 100.0}% Full. Level is ${r._level}"
//bytes(v: "The value is ${r._value}")
return {headers: headers, data: json["encode"](v: {r with _message: alert_msg})}
data =
from(bucket: "bucket")
|> range(start: -5m)
|> filter(fn: (r) => r["_measurement"] == MEASUREMENT)
|> filter(fn: (r) => r["_field"] == FIELD)
|> toInt()
// |> last()
|> map(
fn: (r) =>
({r with _level:
"crit"
"warn"
else
"ok",
|> filter(fn: (r) => r._level == "ok" or r._level == "warn" or r._level == "crit")
lastAlertData =
from(bucket: "bucketalerts")
|> range(start: -7d)
|> group(columns: ["host"], mode: "by")
|> sort(columns: ["_time"])
|> last()
|> keep(columns: ["_value", "host"])
|> rename(columns: {_value: "lastReportedLevel"})
levelInfoData =
data
|> filter(fn: (r) => r["_field"] == "Percent_Processor_Time")
|> keep(columns: ["_level", "_time", "host"])
pivotedData =
data
|> schema.fieldsAsCols()
|> filter(fn: (r) => exists r.Percent_Processor_Time)
unionedData =
union(tables: [levelInfoData, pivotedData])
|> group(columns: ["_time", "host"], mode: "by")
|> sort(columns: ["host"])
|> fill(column: "_level", usePrevious: true)
|> tail(n: 1)
|> group()
|> sort(columns: ["host", "_time"])
|> map(fn: (r) => ({r with msg_grp: msg_grp}))
|> map(fn: (r) => ({r with _check_name: _check_name}))
statusChanges =
unionedData
|> monitor.stateChangesOnly()
countChanges =
statusChanges
|> count(column: "_level")
|> rename(columns: {_level: "changesCount"})
keepLowCountAndChange =
union(tables: [statusChanges, countChanges, lastAlertData])
|> fill(column: "changesCount", usePrevious: true)
|> fill(column: "lastReportedLevel", usePrevious: true)
|> tail(n: 1)
|> map(
fn: (r) =>
({r with lastReportedLevelTemp:
if exists r.lastReportedLevel then r.lastReportedLevel else "none",
|> drop(columns: ["lastReportedLevel"])
|> rename(columns: {lastReportedLevelTemp: "lastReportedLevel"})
|> filter(fn: (r) => r["_level"] != r["lastReportedLevel"])
|> filter(fn: (r) => r["changesCount"] < FLUCTUATION_CAP)
// If goes from warn to ok but used_percent more than 75%, exclude
|> filter(
fn: (r) =>
not (r["lastReportedLevel"] == "warn" and r["_level"] == "ok"
and
r["Percent_Processor_Time"] >= 75),
// If goes from ok to warn but used_percent less than 85%, exclude
|> filter(
fn: (r) =>
not (r["lastReportedLevel"] == "ok" and r["_level"] == "warn"
and
r["Percent_Processor_Time"] <= 85),
// If goes from crit to warn but used_percent more than 89%, exclude
|> filter(
fn: (r) =>
not (r["lastReportedLevel"] == "crit" and r["_level"] == "warn"
and
r["Percent_Processor_Time"] >= 89),
// If goes from warn to crit but used_percent less than 92%, exclude
|> filter(
fn: (r) =>
not (r["lastReportedLevel"] == "warn" and r["_level"] == "crit"
and
r["Percent_Processor_Time"] <= 92),
|> endpoint()
//|> filter(fn: (r) => r["lastReportedLevel"] != "none")
|> set(key: "_measurement", value: MEASUREMENT)
|> to(org: "org", bucket: "bucketalerts", fieldFn: (r) => ({"_level": r._level}))
