where can i get information about the new “spinners” that appear in all table cells just observed after updating to chronograf 1.8.4?? intended purpose, expected behavior, etc.
Hello @QuantEnabler,
Welcome! You probably want to check out clockface. I found this and an example of how to use it here, which might be helpful?
not quite addressing the issue, but thanks for the response.
attaching image of what i am observing
if i drag the handle to resize the entire table panel the lines then fall into properly sized (height) space.
i wasn’t sure if there were some new functionality where one would scroll through elements within each cell
@QuantEnabler,
Sorry I’m having trouble understand what you question is. I think that scrolling is available for very large tags or numbers, if that’s what you’re asking.
