I want to query the sum per minute from the result obtained from another query that calculates the difference between subsequent values.
select sum(ph1), sum(ph2), sum(ph2) from (select
non_negative_difference(day_chan1) as ph1,
non_negative_difference(day_chan2) as ph2,
non_negative_difference(day_chan3) as ph3
from electricity)
group by time(1m) tz('Europe/Dublin')
For example if I get the following from the suqbquery
time ph1 ph2 ph3
2017-04-02T14:40:38Z 0 0 2
2017-04-02T14:41:38Z 1 1 1
2017-04-02T14:41:39Z 0 0 2
2017-04-02T14:42:38Z 1 1 1
2017-04-02T14:42:39Z 0 1 2
I want to sum them up into
time ph1 ph2 ph3
2017-04-02T14:40:00Z 0 0 2
2017-04-02T14:41:00Z 1 1 3
2017-04-02T14:42:00Z 1 2 3
but what I get from the query is aggregate function required inside the call to non_negative_difference but if I do the sub query on its own, it returns the results
