I use influx 1.7.8
In two influx instances, I have (I think) the same records. The first influx was created about 4 months ago, and the other one was created a week ago. I migrated data from the first to the other.
When I count records I receive the same number of records.
select count(field1) as res from table1 where time>='2021-12-01 00:00:00' and time<'2021-12-31 00:00:00' group by time(1d)
When I fetch all records from that time I receive the same records.
select field1 as res from table1 where time>='2021-12-01 00:00:00' and time<'2021-12-31 00:00:00'
When I sum the values of fields I received different results.
select sum(field1) as res from table1 where time>='2021-12-01 00:00:00' and time<'2021-12-31 00:00:00' group by time(1d)
There are thousands of records in table ‘table1’.
What causes the problem?
Thanks in advance.
