I am getting data from aws kinesis and I am pushing to influxdb. Data is separated by Venue tag, denoting Venue as a unique location. In influxdb I am calculating kpi using task which is running every hour, so what happens is there is delay in the oms which can extend from 15 min to 2 hours. So, for example I am receiving 1 tar file from each venue. Data for 11 am should come at 12 pm, however due to delay, it might go until 2 pm.
I need to run tasks in such a way that, if for any venue I am got the data, I need to calculate the kpi. How Can I do that. I thought of running tasks at 15 mins or 30 mins instead of 1 hour, but in that case the already computed Venue will again be computed.
Hello @Anaisdg I need your help for following query:
Say table1 = return all values of a particular tag in last 7 days
and table2 = return all values of particular tag in last 1 hour
I need all those values which are present in table1 but not in table2. How to do that?
Maybe the join() function to combine the two tables and then filter the results based on whether or not the value is present in both tables, like this?
