Hi there. I use Influxdb with Kapacitor(for alerting) on single machine in different docker containers with host net.
I have about 500k points writes(over UDP) every 10 minutes. This measurement has CQ for downsampling every 1 hour(about 3 millions points). And this new measurement are downsampled every 1d(about 12 million points).
And I have this TICK script:
dbrp "prices"."one_hour"
var prices = stream
|from()
.measurement('hourly_prices')
.groupBy('product_id')
|window()
.period(20m)
.every(10m)
.align()
|derivative('value')
.unit(10m)
.as('derivative')
|alert()
.warn(lambda: "derivative" != 0)
.message('')
.details('')
.post('SOME_URL')
So I have two different problems:
- Memory usage is growing over time(and in time where 1d CQ are running Memory usage jump to 100%)
- When Kapacitor starts “write/consistency” queries from influx to kapacitor goes very fast (about some milliseconds) and over time they take more time and as result I get an error:
net/http: request canceled (Client.Timeout exceeded while awaiting headers)" log_id=0HhYMpn0000 service=subscriber
- Also I notice that not all alerts are triggered
My Influx conf:
reporting-disabled = true
bind-address = "127.0.0.1:8088"
[meta]
dir = "/var/lib/influxdb/meta"
retention-autocreate = true
logging-enabled = true
[data]
dir = "/var/lib/influxdb/data"
index-version = "inmem"
wal-dir = "/var/lib/influxdb/wal"
wal-fsync-delay = "0s"
validate-keys = false
query-log-enabled = false
cache-max-memory-size = 1073741824
cache-snapshot-memory-size = 26214400
cache-snapshot-write-cold-duration = "10m0s"
compact-full-write-cold-duration = "4h0m0s"
compact-throughput = 50331648
compact-throughput-burst = 50331648
max-series-per-database = 0
max-values-per-tag = 0
max-concurrent-compactions = 0
max-index-log-file-size = 1048576
series-id-set-cache-size = 100
trace-logging-enabled = false
tsm-use-madv-willneed = false
[coordinator]
write-timeout = "10s"
max-concurrent-queries = 0
query-timeout = "0s"
log-queries-after = "0s"
max-select-point = 0
max-select-series = 0
max-select-buckets = 0
[retention]
enabled = true
check-interval = "30m0s"
[shard-precreation]
enabled = true
check-interval = "10m0s"
advance-period = "30m0s"
[monitor]
store-enabled = true
store-database = "_internal"
store-interval = "10s"
[subscriber]
enabled = true
http-timeout = "30s"
insecure-skip-verify = false
ca-certs = ""
write-concurrency = 40
write-buffer-size = 1000
[http]
enabled = true
bind-address = ":8086"
auth-enabled = true
log-enabled = false
suppress-write-log = false
write-tracing = false
flux-enabled = true
flux-log-enabled = false
pprof-enabled = true
debug-pprof-enabled = false
https-enabled = false
https-certificate = "/etc/ssl/influxdb.pem"
https-private-key = ""
max-row-limit = 0
max-connection-limit = 0
shared-secret = ""
realm = "InfluxDB"
unix-socket-enabled = false
unix-socket-permissions = "0777"
bind-socket = "/var/run/influxdb.sock"
max-body-size = 25000000
access-log-path = ""
max-concurrent-write-limit = 0
max-enqueued-write-limit = 0
enqueued-write-timeout = 30000000000
[logging]
format = "auto"
level = "info"
suppress-logo = false
[[udp]]
enabled = true
bind-address = ":8089"
database = "prices"
precision = "s"
[continuous_queries]
log-enabled = true
enabled = true
query-stats-enabled = true
run-interval = "5m"
[tls]
min-version = ""
max-version = ""
And Kapacitor conf:
hostname = "SOME_HOST"
data_dir = "/var/lib/kapacitor"
skip-config-overrides = false
default-retention-policy = ""
[http]
bind-address = "0.0.0.0:9092"
log-enabled = true
https-certificate = "/etc/ssl/kapacitor.pem"
[load]
enabled = true
dir = "/etc/kapacitor/load"
[replay]
dir = "/var/lib/kapacitor/replay"
[task]
dir = "/var/lib/kapacitor/tasks"
snapshot-interval = "60s"
[storage]
boltdb = "/var/lib/kapacitor/kapacitor.db"
[[influxdb]]
enabled = true
default = true
name = "localhost"
urls = ["http://HOST_IP:8086"]
username = USERNAME
password = PASSWORD
timeout = 0
startup-timeout = "5m"
disable-subscriptions = false
subscription-mode = "cluster"
subscription-protocol = "http"
subscriptions-sync-interval = "1m0s"
kapacitor-hostname = "SOME_HOST"
http-port = 0
udp-bind = ""
udp-buffer = 1000
udp-read-buffer = 0
[influxdb.subscriptions]
DB = [ "one_hour" ]
