Hi
I am trying to create a query to sort the last field of each measurement descending.
This is my query:
from(bucket: "iobroker")
|> filter(fn: (r) => r["_measurement"] == "loxone.0.1990ece5-000b-a827-ffffb2ef6a95b230.value" or r["_measurement"] == "loxone.0.167f5741-037a-8b3d-ffffb2ef6a95b230.value" or r["_measurement"] =="loxone.0.1826dbac-0057-2552-ffffb2ef6a95b230.value")
|> filter(fn: (r) => r["_field"] == "value")
This will show the output like this (in Grafana)
57
1.23
21.6
i wish to have it like:
57
21.6
1.23
This is the raw data:
I tried to use the sort and group functions but the results always come out weird. I cant seem to figure out what the correct syntax or functions are to accomplish this.
Kind regards
Kevin
If you use Grafana (9+), you can sort it there.
Use the Transform panel that is next to the Query tab and look for the Sort by function:
Hi
Will this not just sort by time? I want to sort so i can see the highest value first. If i try your solution:
I would presume i need to do the sorting in the flux query itself?
In Data explorer from influxDB the follwing query works, but i cannot paste this in grafana, it doenst show any value.
|> filter(fn: (r) => r["_measurement"] == "loxone.0.1990ece5-000b-a827-ffffb2ef6a95b230.value" or r["_measurement"] == "loxone.0.167f5741-037a-8b3d-ffffb2ef6a95b230.value" or r["_measurement"] == "loxone.0.1826dbac-0057-2552-ffffb2ef6a95b230.value")
|> sort(columns: ["_time"], desc: true)
|> last()
|> group(columns: ["_result"], mode:"by")
|> sort(columns: ["_value"], desc: true)
Kind regards
Kevin
Well then select a different field from the dropdown list.
