[Solved]How to find gaps in my data?
I’m looking for a query that will return to me all of the times where i’m missing data for over than 30 minutes (because of some bug or disconnection).
Lets say I have this data:
time [other data (irrelevant)…]
2017-11-01T20:00:00.000000000Z
2017-11-01T20:01:00.000000000Z
2017-11-01T20:02:00.000000000Z
2017-11-01T20:03:00.000000000Z
2017-11-01T20:50:00.000000000Z
2017-11-01T20:51:00.000000000Z
I would like the query to return:
time
How can I write that query?
Thanks in advance.
I found the answer I was looking for:
select * from (SELECT max(“money”) FROM table WHERE time > ‘2017-07-30T21:00:00Z’ GROUP BY time(2m) fill(-10000)) where max = -10000;
Couldn’t query with nulls so I just inserted some values of -10000 to the nules, there might be a better solution but this one works for me.
Interesting hack, but it has a few problems:
  1. It doesn’t show the exact time where a gap starts, but a time multiple of the GROUP BY value (2m)
  2. It shows every single gap separately, even if they form a continuous gap. A 10-minute gap will show as 5 2m gaps.
Here’s a better and simpler solution, using a subquery:
SELECT * FROM (
  SELECT ELAPSED("money", 1m) AS "gap"
  FROM table
  WHERE ...
) WHERE gap >= 2
This addressed both problems above; it will show
  • the exact points at the ends of the gaps, and
  • the exact contiguous length of the gaps bigger than 2 minutes, no matter how long they are.
Would be nice if you could run SELECT ELAPSED(...) AS "gapSize" WHERE gapSize > ... directly. Worth an upvote?
What if the gap is at the start of your data? Won’t the elapsed function miss those records. For instance, if I set my query for -7d but the last available record is -5d, since the elapsed function takes differences between records, wont this miss it.
If it does, is there a way to include the missing records in the above query?
