Show tag is not showing all the tag values
In our telegraf config we give ip manually and get hostname from hostname command, and by mistake we added one ip as two different servers, ip and hostname both are tag keys,
so now we had two hostname for one ip. and
SHOW TAG VALUES FROM “cpu” WITH KEY = host
would never show the correct hostname, but it would show the hostname of the other host were ip was configured wrong.
even after the correction in config we are not able to see the correct host while we can get data for that host via command like this.
select * from cpu where host=‘XXX’ group by *
but this host does not shows in
hi @Amit_Kumar_Singh ,
what is the output of
show tag keys from cpu
and
show field keys from cpu
best regards ,
Below is the response.
tagKey
app_stack
cpu
host
ip
os
and
fieldKey fieldType
usage_idle float
usage_iowait float
usage_system float
usage_user float
could you share this after replacing the data you don’t want to be visible with xxxxx ?
   select * from cpu where host=‘XXX’ group by * limit 1
tags: app_stack=XXX, cpu=cpu-total, host=XXX, ip=XXX, os=aix7.1
time usage_idle usage_iowait usage_system usage_user
1556014717851364256 97 0 2 1
Hi @Amit_Kumar_Singh ,
could be related to this bug …
tag values
