SHOW RETENTION seems unavailable in ver. 3.8 OSS/Core
Even though the documentation at influxdb3 show retention | InfluxDB 3 Core Documentation states this command is available, it clearly is not.
influxdb3 --version
influxdb3 3.8.0,
error: unrecognized subcommand ‘retention’
So, a few questions.
  1. Is this a documentation bug or an issue with the CLI?
  2. I have set the retention during database creation but I am unable to verify it with this command not being available. Are there other options to verify the retention is enabled on a database?
  3. Will switching to Enterprise Home help?
Thanks.
Thanks for bringing this up, looks like a bug and I’ve informed our engineering team, will share update soon.
Thanks for responding.
Any chance you can also respond to the other 2 questions in my original post?
  1. I have set the retention during database creation but I am unable to verify it with this command not being available. Are there other options to verify the retention is enabled on a database?
  2. Will switching to Enterprise Home help?
That command works on Enterprise so you will be able to run it there if you switch to Enterprise however it will be coming into Core very soon as well.
