alexp
July 29, 2021, 8:40am
1
im quiet new to fluxlang so im really struggling with creating queries.
I have the following situation:
there are N sensors on each floor in a house.
the sensors are sending values not constantly.
What i want to see as data is the latest value of each sensor that has sended data in i.e. the last 5mins (timeframe)
If a sensor has sent no data, it should not appear in the data list
i tried to define a query, but it gives me only one sensor.
Any suggestions?
from(bucket: "sensor.test")
|> range(start: -5m)
|> filter(fn: (r) => r["floor"] == "topfloor")
|> filter(fn: (r) => r["_field"] == "p")
|> last()
Have you checked this query in the GUI?
How often does each sensor send data?
What happens if you increase the range? Do you see more sensors?
alexp
July 29, 2021, 5:09pm
3
sure i cheched the query in the GUI.
i made a small script that creates some mock data for the sensors within the given timeframe.
so data is definitively there.
but in the end i see only one datapoint in the table
function addData() {
const writeApi = client.getWriteApi(org, bucket);
console.log("write datapoint for");
writeApi.useDefaultTags({ floor: "topfloor" });
for (let index = randomNumber(0, 3); index < randomNumber(5, 8); index++) {
writeApi.writePoint(
new Point("sensor_" + index).floatField("p", randomNumber(-10, 20))
writeApi
.close()
.then(() => {
console.log("close write API");
.catch((e) => {
console.error(e);
console.log("\\nFinished ERROR");
alexp
July 30, 2021, 11:45am
4
does anyone have any suggestions?
