@fastxl This is going to get a little crazy, but I included comments in the query to explain what is happening:
The dashboard cell query
import "array"
import "dict"
import "strings"
// Extract the _value of the last record as a scalar string.
myItem =
(from(bucket: "LB3000")
|> range(start: today())
|> filter(fn: (r) => r.deviceId == "Okuma-LB3000" and r.dataItemId == "Lp1CommonVariable")
|> last()
|> findRecord(fn: (key) => true, idx: 0))._value
// Split the scalar string by the space and return an array of strings.
spacesplit = strings.split(v: myItem, t: " ")
// Iterate over the spacesplit array and split each element by colon.
// For each item in the arry, return a record with two properties: key and value.
paramList =
array.map(
arr: spacesplit,
fn: (x) => {
_split = strings.split(v: x, t: ":")
return {key: _split[0], value: _split[1]}
// Structure the paramList array as a dictionary to allow for dynamic access at
// query time.
paramDict = dict.fromList(pairs: paramList)
// Define what parameter to select from the paramDict dictionary.
paramKey = "1"
// Build an ad hoc table with only a _value column that is populated by selecting
// the paramKey from the paramDict dictionary.
array.from(rows: [{_value: dict.get(key: paramKey, dict: paramDict, default: "No value")}])
Now, since you’re going to be using this in a dashboard, I’d recommend defining the paramKey
variable in this query with a dashboard variable. So first you need to define a dashboard variable that lets you select from the available parameters in the string (See Create a dashboard variable). Use a “Query” variable type and the following query to return all of the parameters
Dashboard variable query to get all the parameters
import "array"
import "strings"
myItem =
|> last()
// For each item in the array, return a record with a _value property.
paramList =
array.map(
arr: spacesplit,
fn: (x) => {
return {_value: _split[0]}
// Build an ad hoc table using the array of values
array.from(rows: paramList)
I’ll just assume the name of the variable is parameter
. Now update your dashboard cell query to use the parameter
dashboard variable and you’ll be able to select which parameter’s value to show in the single stat cell:
Final dashboard cell query with selectable parameter variable
import "array"
import "dict"
import "strings"
myItem =
|> last()
paramList =
array.map(
arr: spacesplit,
fn: (x) => {
// query time.
paramKey = v.parameter
