Select data from last month
Hello!
I want to select all data from last month depends on actually date.
Example: today 2018-06-21 -> I need all datas from 2018-05-01 - 2018-05-31
with
SELECT * FROM “” WHERE time >= 1525125600000000000 and time <= 1527803999000000000
I will get it. But the Timerange should variable (depends on “today”)
somthing like this:
SELECT * FROM “” WHERE time = month(today)-1
the last 30 days I will get with time < now() - 30d
Is this possible?
rg
Hansi
I think you should be able to run a query like this:
select * from “” where time <= now() and time >= now() - 30d
Hello
Thank you for replay.
But I need the data from previous month fot for last 30 days().
Like SELECT * FROM “” WHERE time =lastmonth()
rg
Hansi
This is a popular feature request that’s on our radar, and will be supported in our new query engine, Flux.
Thank you for Information
rg
Hansi
How is this accomplished using Flux? The closest I could get is using this, but that still does the last 30 days, not the current month.
|> range(start:-30d, stop:now())
Thanks for your help!
Hi @jordanwade33 , welcome to the community ,
It is not easy to implement ,but as a workaround you can use
An Absolute time range in that link you can see following example …
 from(bucket:"telegraf/autogen")
  |> range(start: 2018-11-05T23:30:00Z,      stop: 2018-11-06T00:00:00Z)
Ps : You can see the status of the implementation if you follow the link @katy has posted,
Hope this helps … best regards,
Hi Marc, Thanks for the quick reply. I’m new to InfluxDB but I’m loving all the things I’m finding it capable of doing.
After your reply, I read through the entire link that you mentioned and there was a lot of good things there. My goal is to have dynamically updated ranges, so I’ve decided to not go with absolute time ranges like you recommended. I did come across some people using window() to get what I’m looking for.
|> window(every: 1mo, period: 1mo)
I don’t quite have enough data yet to tell if it’s working, but I’ll keep an eye on it and continue to play with it. Thanks again!
