Created an influxdb container,
docker run -p 8086:8086 -d --name influxdb2 -v /home/user/tick-stack/influxdb2:/var/lib/influxdb2 -v /home/user/tick-stack/influxdb2/config:/etc/influxdb2 influxdb:2.4
Config file (/home/user/tick-stack/influxdb2/config/influx-configs)
[default]
url="http://192.168.10.4:8086"
token="nlGp2Zyg1Ioi5hAW67Asg_fYYIWmS29XEd25gSINevFqA23xvnRxlTMChciHDIFQqCVvhrsJayDFwQ9dWz3OeA=="
org="my-org"
active=true
[logging]
level = "warn"
But I am seeing the following message in the docker logs, not sure whats its all about,
ts=2022-09-15T17:03:36.026516Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.026634Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.064739Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.430481Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.497015Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.630071Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.857328Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:36.926554Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:37.545849Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:37.625427Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:37.802857Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
ts=2022-09-15T17:03:37.839186Z lvl=info msg=Unauthorized log_id=0cxXXy~l000 error="authorization not found"
