Hey,
We have 10000 sensors with 15 second measurements.
We want to make averages per minutes for each of the sensors then aggregate all the series by summing them.
I have designed the database to have a measurement by sensor but I can‘t find a solution to build my request.
What is the solution ? find a good query ? or change the schema and create only one (big) measurement with specific tag ?
Thank you in advance,
