I would like to run influxdb API, reverse proxy by NGINX. The whole application is hosted on azure VM. I have opened the port 80 and 443 in VM. Can I know why I still cannot get the connection of the API. Here is my NGINX configuration in conf.d.
upstream influxdb {
server 20.6.73.180:8086;
server {
listen 443;
listen [::]:443;
server_name vm2nginx.southeastasia.cloudapp.azure.com;
location /api/v2/ {
proxy_redirect http://influxdb http://influxdb/api/v2/;
proxy_pass_header Server;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Scheme $scheme;
proxy_set_header Host $http_host;
proxy_pass http://influxdb;
