I keep getting the below error, but I can’t figure out what is causing it. How do I get more detail about which part of my config is causing this?
At the same time, I’m using the exact same config on other servers without errors… only difference between the two is Ubuntu 14 (working) vs Ubuntu 16 (not working).
It’s possible there’s some environmental change I need to make that I haven’t made, but I’m not sure what…
So how do I figure out what part of my telegraf config is causing this error?
2017-09-27T17:53:10Z E! Parse error; dropping points: Response Error: Status Code [401], expected [204], [unable to parse authentication credentials]
Using Telegraf v1.4.0
Thanks!
