How can I remove the timestamp from the columns from the following table using fluxlang? :
I can do it manually using overrides :
but i prefer to do it directly in the query instead. Anyone ideas?
Thanks,
@bart What are you using to display the data? Flux doesn’t include the timestamp in column names, so this is a convention of whatever client you’re using.
this is a grafana client to show the data. Probably it’s something in grafana then
