Regex with NOT in TICK script where condition
Hi
I can use the regex in the where condition =~
Lets say I have condition where host matches anything starting with chelinflx , I can specify the condition lambda: “host” =~ /.chelinflx./
How should I specify if I want to consider host not equal to any host starting with chelinflx.
Thanks,
Rishma
Try lambda: "host" !~ /.chelinflx./
Thanks Nate. If I have drive like anything after /mnt, Please guide how should I specify that.
To be more clear:
If I use the below condition , it does not work. I want to exclude all the disk mount points starting with /mnt
lambda: “path” !~ ‘/mnt./’
This should work:
lambda: "path" !~ /^\/mnt/
Thank you Nate. It helped
Hi Can we add multiple path in same Lambda expression ???
like below
/^/app/ | ^\/var\/ /
