Can the limit of 1M cardinality be overcome by splitting the data into different buckets (assuming that splitting the data will reduce the series cardinality, i.e. only a certain tag value will appear in a bucket)
Hi @raiden-x,
Yep, this is a perfect example of reducing overall cardinality. I would also take a look at the Cardanilty Monitor template. This will help you monitor each bucket: community-templates/influxdb2_operational_monitoring at master · influxdata/community-templates · GitHub
Also welcome to the community ![]()
Thanks for the answer and the resources
