Hi. Is there a way to set the recovery message? I’m receiving the same message as the alert in slack but with a green dot for recovery. Ideally I’d like to set a recovery message.
Hi. Did you figure this out?
I have the same issue and it doesn’t look like something that was not thought through! May be, I am missing something.
HI, you can use the following
{{if eq .Level “OK”}} show your OK message {{else if .eq Level “WARNING”}} display the warning message {{else}} display critical message{{end}}
The order of the evaluations doesn’t really matter. so you could include the warning/critical messages first then as the final {{else}} part you can add the OK message.
The syntax might be slightly off. There is a topic covering this on here somewhere I’ll try and find some docs.
Hope that helps
Edit: Template syntax
Edit 2: String templates, just after example 8
Kapacitor Doc
That was exactly what I was looking for. Thank you very much.
No problem @niranjansm Glad it helped.
