Query to get top N disks with high IOPS average over given period
I came up with below query that would display disk names which have high IOPS (average) for a given period. I want to get it reviewed here to see if there could be a room for improvement. I also wonder if this can somehow be made into one single query instead two.
My approach is use two queries
query 1 - get the top N disk names with high IOPS average
query 2 - make use of query 1 data as filter to display the high IOPS consuming disks.
REQ_FIELD = "reads"
// QUERY 1: query to collect top 5 disk names with high reads for a given time range
top_n_ds_names = from(bucket: "disk_metrics_bucket")
|> range(start: 2023-11-09T07:17:19.148Z, stop: 2023-11-09T13:17:19.148Z)
|> filter(fn: (r) => r._measurement == "disk_metrics" and
r["_field"] == REQ_FIELD and
contains(value: r["host"], set: ["foo_server"]))
|> drop(columns: ["host"])
|> highestAverage(n: 5, groupColumns: ["disk_name"])
|> keep(columns: ["disk_name"])
|> findColumn(fn: (key) => true, column: "disk_name")
// QUERY 2
// Show results only for those disks returned by QUERY 1
// Note: my use case is such that I need to use `derivative`
contains(value: r["host"], set: ["foo_server"]) and
contains(value: r["disk_name"], set: top_n_ds_names))
|> aggregateWindow(every: 1m, fn: last)
|> derivative(unit: 1s, nonNegative: true)
|> fill(column: "_value", value: 0.0)
|> yield(name: "non_negative_derivative")
P.S: I would be using this query inside a Grafana Dashboard.
Thank you!
Can someone kindly help me on this.
Hello @chidori,
Sorry for the delay.
That looks like a good query to me. I can’t think of a way to execute that logic in one query. Sorry to be the bearer of bad news in that way. It looks like your query is great.
Thank you for the response. On another note, I wanted to add timedMovingAverage() to my query and the param period ( one of the function param for timedMovingAverage() I want it to be the window range I have chosen in grafana. Can you please suggest if this is doable?
