Purge data on InfluxDB
Firstly I’m new to InfluxDB and databases in general, Influx is amazing and I’m using if with Grafana.
I set up a few databases and one is called ‘telegraf’, to my astonishment it’s around 30GBs in size. How can I tell the retention policy has successfully completed? As today I came back from holiday and the server had run out of space.
SHOW RETENTION POLICIES ON “telegraf” = 168 hours so 30GBs must be a weeks with of metrics?
Can I force a purge if it hasn’t run properly as it was out of space?
Hello @G0nz0uk,
I’m so happy to hear that! Thanks for your question. You can either use the drop shard or delete commands to manually delete data.
