I tried to integrate Chronograf into Azure AD. My problem is that the chronograf in running inside a pod (server) which does not have direct access to the internet. Is there a way to configure a proxy in order for chronograf to use this when accessing “https://login.microsoftonline.com/”? The issue can be seen in the pod when using netstat -an. chronograf tries to open a direct connection to login.microsoftonline.com (IP: 40.126.31.141) which is not possible/allowed in the environment of my customer. Configuring an “http_proxy” or “https_proxy” didn’t change anything. It seems that chronograf is not using those settings. I am using version 1.8.8 of Chronograf.
~ $ netstat -an
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State
tcp 0 1 172.25.21.20:36544 40.126.31.141:443 SYN_SENT
tcp 0 0 :::8888 :::* LISTEN
tcp 0 0 ::ffff:172.25.21.20:8888 ::ffff:172.25.20.1:59838 TIME_WAIT
Thanks for any hints, ideas
