Problem with Map syntax
I’m trying to do simple math on the results of a pivot and I am getting “null” values. Substituting in fixed integer or float values it works as expected, so I assume that I am not piping the values into the function, but I can’t figure out where I went wrong.
from(bucket: "IotaHourly")
  |> filter(fn: (r) => r["ct"] == "AC1" or r["ct"] == "AC2" or r["ct"] == "AC3" or r["ct"] == "PNL-Kitchen" or r["ct"] == "PNL-Laundry" or r["ct"] == "TeslaWC")
  |> drop(columns: ["device", "_measurement", "_start", "_stop", "_field"])
  |> pivot(rowKey: ["_time"], columnKey: ["ct"], valueColumn: "_value")
  |> map(fn: (r) => ({r with House: r._AC1 + r.AC2 + r.AC3 + r["PNL-Kitchen"] + r["PNL-Lauandry"] - r.TeslaWC }))**
Any tips (and explanation) where I went wrong? Looking at the output as a table the input numbers all look good and it is clear that the output is “null”.
Everything was taken from the Documentation Example
Hello @Patrick808,
I believe you’ll have to group your data before you pivot it if you want to create calculations across those different tags.
  |> group()
@Patrick808 It’s because you have null values in your math operations. If any operands in a mathematic operation are null, the operation returns null.
There are two things I can think of that will cause this:
  1. You have points with null values (pre-pivot)
  2. Your timestamps don’t perfectly align, so as a result of the pivot, some rows don’t have values for some of the columns used in your map operation.
I suspect it’s probably #2. There are a few solutions:
  1. Use fill() to fill each of the columns in the pivoted data. Pivoted data does make this process a little cumbersome since fill() can only fill one column at a time:
        |> fill(column: "_AC1", value: 0)
        |> fill(column: "AC2", value: 0)
        |> fill(column: "AC3", value: 0)
        |> fill(column: "PNL-Kitchen", value: 0)
        |> fill(column: "PNL-Lauandry", value: 0)
        |> fill(column: "TeslaWC", value: 0)
  2. You can normalize the timestamps to a precision where points should all align. For example, if you’re seeing sub-second differences in timestamps between all the different fields, you can normalize the timestamps to the second. To do this, use truncateTimeColumn() before you pivot the data:
        |> truncateTimeColumn(unit: 1s)
Truth be told, you may need to do both of these. If timestamps still don’t align after normalizing/truncating the time values, you will still have to fill all the null columns.
I don’t think either explanation checks out.
This is what the table from the pivot shows:
Ah, I see the issue. You have an underscore (_) in front of AC1 in your map() call. That column doesn’t exist in the data, so it’s returning null. Remove the underscore and you should be good to go.
Doh… Thanks. So much for checking seven times!
No problem. Happy to help!
