Hi
I need to apply a custom http header - for credentials - when trying to fetch/scrape metrics from Prometheus. I will try to use the Telegraf Agent plugin.
At a first read-through I do not see such an option.
Best regards
/Bengt Evaldsson
Hi
Best regards
/Bengt Evaldsson
Hello @bevaldss,
I don’t know if this is possible. I’m asking around. Thank you for your patience while I find the answer.
Out of curiosity, what header are you trying to add?
There isn’t support for custom headers currently, but there are a few supported by the plugin, like basic and bearer tokens for authentication.
