Plot the difference between two stream/data
I have a random data like this:
The query that I used:
data1 = from(bucket: "testBucket")
  |> range(start: -3h)
  |> yield(name: "data1 ")
data2 = from(bucket: "testBucket")
  |> range(start: -3h)
  |> timeShift(duration: 1h)
  |> yield(name: "data2 ")
How to get and plot the difference between these stream. Basically I want something like this:
data1 - data2
Thanks !!
Hi @HarimbolaSantatra
I would use the join.inner() function. You define your two streams as a “left” and “right” side, and use a predicate function on to define how they should match up. Something like this:
import "join"
|> range(start: -3h)
|> filter(fn: (r) => r._measurement == "example")
// Ensure data is aligned to the same time grid
|> aggregateWindow(every: 1m, fn: last, createEmpty: false)
|> range(start: -3h)
join.inner(
    left: data1,
    right: data2,
    on: (l, r) => l._time == r._time,
    as: (l, r) => ({
        _time: l._time,
        // We pull the values from the left and right records
        val1: l._value,
        val2: r._value,
        difference: l._value - r._value
